Question on my 2017 G25 - Do I run with the battery switch turned to “On” and when I turn off the engine at the sandbar and listen to music I need to turn the switch to the yellow area that says “Combined”?
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Don't turn it to combined in that situation. That's a great way to not be able to start the boat after listening to music. Leave it set to ON, and only use Combined if the main battery is dead when you go to start the boat.
FYI, they automatically combine once the engine is running so that the alternator can charge them both.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Yes, I would always leave it on Auto and High. It will help keep the boat on plane in turns, and help it plane better when starting out. I'd set the user setting to Back to Dock, and leave NCRS on Auto/High.
One thing you might consider is setting the NCRS setting to ZERO (still in Auto/High) in the Back to Dock profile, which is what you should be using when just cruising around. This will keep the bow down, and actually reduce fuel consumption a small amount. This can be proven by cruising at a certain RPM with NCRS set to 5, and then change it to ZERO and look at your speed. It should be about a mile an hour or so faster at ZERO when at the same RPM. The boat runs more efficiently this way. Of course when pulling a rider (using a different profile), NCRS should be set appropriately to produce the wake the rider wants.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
So if I set it to zero and have the auto on high, the ncrs will continue to work and get better fuel mileage? Not sure if this is against the forum rules but I’d love to be able to speak with you over the phone to make sure I know everything I need to know. I recently bought this boat and it’s a little overwhelming with all of the controls. If you’re willing to call me sometime my number is 662 275-0670. Thanks for your time
