Little "chatter" in gear at very low RMP
  • chagrin 236 nautique
    • Aug 2021
    • 15
    • Cleveland, Ohio
    I am new to the forum - hope I am doing this correctly. We have a 2007 236 that we purchased 3 years ago. Boat runs great and has very low hours on it. As we left the dock this weekend we had a little chatter every once in -awhile at slow the slowest speed. As we put load onto the engine it sounds fine and no issues. Thought maybe prop was loose - but it seems fine. We recently added a clean air exhaust - so maybe now we are hearing more as the boat is quite. Should we be concerned on that sound or is that normal at a very slow RMP to hear it chatter every once in while?
    Second - I am wanting to change transmission oil but can find very little support if we have a transmission filter. We have a PCM Power Pls 2007 transmission. DO we do fluids in both the Transmission and the V drive - or are they one. Sorry to sound stupid - just trying to learn the system. Any professionals or websites you know of to buy supplies for the transmission would be great to know!
  • Skiyal8r
    • Oct 2018
    • 3
    • Ontario Canada
    • 2006 SANTE 220
    I’m experiencing the same sound on a 2006 220. Hopefully someone has some insight on this.
    • ScooterMcgavin
      • 1478
      • 2014 SAN 210 TE
      My 06 210 did it too. It’s pretty annoying but has something to do with the damper plate
      1989 Sport Nautique
      • SilentSeven
        • Feb 2014
        • 1866
        • Bellevue WA
        • 2004 Nautique 206
        Should be able to find trans/fluid details this manual
        https://www.planetnautique.com/Corre.../2007PCMOM.pdf
        I have yet to see a trans filter on any boat...there are typically trans coolers.
        Bellevue WA
        • NautiqueTim
          • May 2023
          • 37
          • North Carolina
          • 1966 Mustang 2001 Air Nautique
          Switching from forward to reverse too fast will cause a short life of the damper plate springs, which can crack or fall out making noise.
          • malibud
            • Jan 2011
            • 58
            • nc
            • 85 2001
            Mine does the same 2007 SANTE
            • swatguy
              • 1631
              • Midwest/ Northern IL
              • 2008 SANTE 210
              The small “rattle “ is very common when you’re barley engaged . It is damper plates, Doesn’t necessarily mean anything is wrong or your should be extremely worried. Bleep the fluid fresh , topped off and change at intervals.
