z5 Cargo Rack Mounting
  • ChattNatique3737
    • May 2023
    • 7
    • Chattanooga, TN
    • 2016 210 SAN
    I've found a new Z5 cargo rack that I’m trying to install on a 2016 210 SAN. I’m looking for the side brackets / Bimini arms / plate kit for the front mounting pins/points. The back has the two stainless struts, and I have the two, 2" circle clamps that I think they attach to... The top is missing the bracket for the front which I think typically mounts to the side of the tower and extends forward. I've read a ton of posts on the forum related to Z5 racks, but I can't find anything that addresses this / installation / mounting. I've also searched for where to buy Z5 mounting hardware with no luck. I've found this (https://www.mniboats.com/bimini-arms...nis-p/5194.htm) from Miami Nautique but am not sure if it's what I need... I've included pics of the boat and top. Any help would be greatly appreciated!!
  • srock
    • Oct 2008
    • 1066
    I can get pictures but you can find them online.
    I have something like this below that the ball end of the tube, with the quick release that slides in and out, drops into then you set the pin to lock the tubes in place. I installed the front brackets first and just fiddled with the top until I had an elevation I liked. Then I installed the rears. Part of the design of the Z5 is the ability to release the rear and tilt the top for access so that is why you mount the fronts and set it in place. I don't use that feature as I just stand on the back sundeck.
    A couple of factors. I did not want mine too high with less shade but just over 6 feet of headroom so I adjusted accordingly. Also, by moving the brackets you have a little adjustability in front, rear, and height. Mount the fronts, leave them barely snug, and you will figure out what you like by just sliding things around.
    If you do not have to take the top down or off for bridges, trailering, lifts the Z5 is awesome. I have an over-the-tower cover and I leave the Z5 in place.
    • H2O
      • Jul 2006
      • 247
      Info I have for mounting Z5 on FCT5 Click image for larger version
Name:	Z5 Arms Red.png
ID:	665564 Click image for larger version
Name:	Z5 Bolt Holes.png
ID:	665565 Click image for larger version
ID:	665566 Click image for larger version
Name:	Z5 Parts.png
ID:	665568 Click image for larger version
Name:	Z5 Tower Clamp.jpg
      • H2O
        • Jul 2006
        • 247
        Z5 arms that bolt to tower NLA. May need to have them fabricated. I do not believe the bimini arms you referenced work for a Z5. Most of the small attachment parts are standard bimini connectors.
        • kylant
          • May 2010
          • 538
          • Lake Tahoe
          210 TOWER & ACCESSORIES 2014.pdf
          take a look here
