Fuel pump wire leaking
  • Drummer1
    • May 2017
    • 26
    • Michigan
    • '04 Nautique SV211
    Hi all, I just discovered that I have a fuel leak coming from the fuel pump wire on my 2004 PCM 330 (04 211). It's spraying from around the sealed grommet where it enters the top housing. (red arrow in pictures)
    I can absolutely take it all apart and explore but I like having some insight before I rip into something. Does anyone know if that grommet/connection point is something that can be purchased separately? If so, could you share where? I checked NP but I'm only seeing the entire unit or fuel lines. Everything is working properly, just getting the spray from that point which is obviously unacceptable and a total show-stopper. Also, I'm mechanical minded but if anyone has experience with this particular issue, I'd really appreciate any procedural hints/experiences that might save some headache. Thanks in advance. .
  • Drummer1
    • May 2017
    • 26
    • Michigan
    BTW, I know some generic bulkhead fittings exist, I just thought there may be a specific one for this application. I like staying with OEM stuff when possible.
    • gary s
      • Mar 2015
      • 334
      • Algonquin IL
      Nautique Parts- https://nautiqueparts.com/repair-kit...trol-cell-fcc/
      • Drummer1
        • May 2017
        • 26
        • Michigan
        Wow, well I guess I didn't look hard enough. It's like when my wife tells me there's something in the fridge and I stare right at it without ever seeing it. Thanks for the link.
        • JayG80
          • Dec 2006
          • 206
          • Santa Fe, TX
          • 2007 Ski Nautique Sold 2002 Ski Nautique
          https://www.planetnautique.com/vb5/f...u-retrofit-kit
          • Drummer1
            • May 2017
            • 26
            • Michigan
            Thank you sir, I swear I did a search before posting but just didn't use the right words I guess. Thanks again.
