Hi all, I just discovered that I have a fuel leak coming from the fuel pump wire on my 2004 PCM 330 (04 211). It's spraying from around the sealed grommet where it enters the top housing. (red arrow in pictures)
I can absolutely take it all apart and explore but I like having some insight before I rip into something. Does anyone know if that grommet/connection point is something that can be purchased separately? If so, could you share where? I checked NP but I'm only seeing the entire unit or fuel lines. Everything is working properly, just getting the spray from that point which is obviously unacceptable and a total show-stopper. Also, I'm mechanical minded but if anyone has experience with this particular issue, I'd really appreciate any procedural hints/experiences that might save some headache. Thanks in advance. .
