Switching out the dash on a 1998 Air to rocker switches. Anyone know what "accy 1" and "accy 2" are from the factory? I can't find anything that changes with them on or off.
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
I would strongly advise against this. Those aren't just switches. They are breakers. They prevent overload of the electrical system. Please replace those with the correct part.
https://nautiqueparts.com/circuit-breaker-switch-dash/
To answer your question, those ACCY breakers aren't connected to anything from the factory. They are for if you want to install additional things. I have used them for underwater lights and things like that in the past.
- Aug 2014
- 380
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
Listen to what Keith said. I would also advise against changing out to unprotected rocker switches. The combination switch/circuit breaker is there for a reason. If the switch gets a little stiff to depress or starts acting up, some people have had good luck by squirting a little WD-40 into the switch post and work it around a bit. On my 1994, I changed out all the switches/circuit breakers during a dash refresh.
JQ
