2002 san transmission problems
  • Jaredmc20
    • May 2023
    • 8
    • Indiana
    • 2002 super air 210
    Seeing if anyone has had this problem. Over the weekend i had a trans failure of some kind. Everything was fine and seemed normal. There was never any slipping or noises from the trans. When taking off just as the boat got on plane it acted like it went to nuetral. I took the cable off and moved the linkage and it does nothing ive checked the fluids they look good they dont seem burnt and theres no shavings that i can tell. If anyone has had something like this happen id appreciate some insight. Also what something like that could potentially cost.
  • biacs
    • Aug 2020
    • 252
    • IL
    • 2006 Nautique 220 Team Edition
    It went into Neutral or it went into limp mode? Limp mode is no RPM revs over idle, but it shifts fine.
    • Jaredmc20
      • May 2023
      • 8
      • Indiana
      it went into neutral. the motor will rev up fine but im not getting anything from the trans.
      • Jaredmc20
        • May 2023
        • 8
        • Indiana
        ive also checked the prop and everything is good down there
        • glassywaters
          • Jan 2015
          • 225
          • florida
          • none
          Could be a broken damper plate.
          • Jaredmc20
            • May 2023
            • 8
            • Indiana
            im hoping thats all it is and not needing a new trans. is there any rebuilding these transmissions or do you have to just buy a new one. also does anyone know roughly the cost of these things.
            • functionoverfashion
              • Jun 2017
              • 509
              • New Hampshire
              • 2003 SANTE
              This is my guess too. Damper plates aren't expensive, but you do have to get between the engine and transmission to change it. On a vdrive that will be a lot of work. Either way, the transmission is coming out. I'd start there, and if you find a broken damper plate, celebrate a little. If not, there are shops that rebuild these transmissions.
