So I bought a 05 Nautique 196, when turning sharp to the right I had a concerning about of water run in and down the carpet on that side, i had two guys on that side and it was a slow turn so it had a lot of water concentrated on that side of the boat up against the rub rail. Would that water be coming through the screws or how would I get that much water coming into the boat at once. It looked like a bilge pump kicked on for about three seconds is how fast the water came in
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
It is likely that the union between the hull and the deck has failing sealer. The correct way to fix this is to pull the rubrail and make sure the hull to deck connection is completely sealed with 5200 (or 4200 if you prefer), and then reinstall the rubrail.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
