2019 Ski Nautique 200 3 out of 4 Courtesy lights not working
  • vegito
    • Jul 2023
    • 9
    • Massachusetts
    • 2019 Ski Nautique 200
    We recently purchased a 2019 Ski Nautique 200 and 3 of the 4 Courtesy lights don't light up, the boat only has ~130 hours, so it is a bit surprising that the bulb would already be dead. Has anyone had this happen? How do you get take them out if we need to replace them? I wasn't able to pull them out. It is the 2 in the back and 1 by the back seat.
  • vegito
    • Jul 2023
    • 9
    • Massachusetts
    Also, has anyone had an issue where after you turn the fuse switch to on, you don't need to input the code to turn on the boat? This was working normally a week ago.
    • jmo
      • Mar 2006
      • 707
      • MA
      On the light I bet it’s a loose wire, especially if it’s towards the back of the boat where the wiring passes through the ski locker. As for the start code, are you sure the prior owner had one set? I intentionally don’t bother setting a code on my 200 as at night my boat is on a lift with key for enabling it.
      I see your in MA, what lake are you on?
      2018 Ski Nautique 200 TE, H6
      • MN Ryan
        • Aug 2020
        • 1250
        • Maple Grove, MN
        • 2007 SV-211 TE
        Betting it's a loose wire on the lights, too. They're LEDs and should last for an eternity. I thought I had a bad one, and it was just a loose connection.
