SV211 Relay Identification Help
  • msh_2
    • Sep 2022
    • 8
    • Alaska
    • 2005 SV211
    I have a new to me SV211. I’m told it’s a 2004, but it doesn’t look like Correct Craft manufactured SV211s until 2005. Long story short, I’m not certain about the year.
    I was tracing a wire and looked behind what appeared to be an aftermarket relay box with three relays (plz see pics). As I moved/peaked behind the plastic panel, half a dozen wires fell out of the back of the relay block. The previous owner told me that the center (“belly”) ballast was an aftermarket addition, so I assume the relays have something to do with the center ballast. I have no idea where the wires go and have no clue if the red and black colors correspond to positive and negative. For instance, there's a large gage wire leaving the battery switch that I believe to be positive, but it's black (plz see pic). To get a better understanding, I might have to tear into the boat to trace wires and test voltage.
    Any help identifying the relay panel, its purpose, and pointing me to a wiring diagram would be greatly appreciated.
    Thanks for your time!
    Marc
  • msh_2
    • Sep 2022
    • 8
    • Alaska
    • 2005 SV211
    bump
    • jpwhit
      • Aug 2016
      • 526
      • Cary, NC
      It looks like a user modification. As such, only the person that did the mod can likely give you any info.
