I ran aground the other night into some sand in a low area in the lake and it looks like this front fin got bent. Does anyone know what this fin is for and if this bend in on it will affect the overall performance of the boat? 2016 G21. Just wonder if I have to order a new one or maybe I could take a rubber mallet and try to shape it back a little bit. Thanks in advance.
A d m i n i s t r a t o r
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
It is a tracking fin. Probably should replace it. They are only about $150.
https://nautiqueparts.com/fin-1991-now/
Use our discount code (PND) for 10% off.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
If that's the worst you did, you did ok. That's a stabilzer or tracking fin. In essence when I'm skiing, on a hard cut my goal is to pull the boat towards me. At 210 lbs I will move your boat. That fin helps you track a straight line and helps me not pull you off course. I would maybe spring for a new one rather than test how strong the gel & fiberglass is vs. flailing mallet.
Edit: Whoops right on top of you Jeff - Ditto
Originally posted by NautiqueJeff View PostIt is a tracking fin. Probably should replace it. They are only about $150.
