2019 GS24 ballast sensor problem?
  • SiliconTiger
    • Aug 2022
    • 1
    • Nevada
    We have the piggyback ballast tanks. We bought the boat used ~2 years ago and everything has been working great. Several days ago noticed when we try and fill the ballast tanks the starboard side very quickly says it's at 100% and the pumps shut off. It's clearly not at 100%. Manually drained to be certain it really is empty. Then try to fill manually several times and pumps only come on for a couple of seconds and then shut off (likely because it thinks it's at 100%). Tried to reset the timers going into the dealer settings but that didn't make any difference.
    From reading this forum, it seems like it's a ballast sensor gone bad and needs to be replaced. Any other opinions what could be going wrong?
    As it's not easy for us to get it repaired, is there anything I can do short-term to force the starboard side tanks to fill even though the sensor is claiming it's at 100%?
    And if anyone has any recent experience replacing a 2019 GS24 ballast sensor I'd appreciate any tips as I may try and do it myself on the water...yikes!
    Thanks!
  • CVAGS20
    • Aug 2022
    • 59
    • Virginia
    • 2018 GS20
    SiliconTiger I too had a similar issue with the ballast system on my 2018 GS20 with piggyback bags (the same symptoms). I took it to my dealer and they diagnosed it as a ballast sensor issue - my boat had the old style sensors. All three sensors were replaced under warranty and I have not had an issue since.
