2008 sv211 Team 343ex Check Engine Light
  • duaneweir
    • Aug 2023
    • 1
    • Christina Lake
    • Maple Ridge British Columbia
    • 2008 sv211 Team
    I have a CEL on my 2008 sv211 Team w/ pcm 343ex that I can not clear. It is low oil and was triggered on an oil change. Will a codemate clear the triggered event? or do I need to purchase the diacom software? I would just take it into the local dealer to clear but they are a 6hr round trip away. Is the ecm running MEFI4?
    Thanks for the education, much appreciated
    Duane
  • jpwhit
    • Aug 2016
    • 526
    • Cary, NC
    A 2008 Ex343 should be an eControls ECM. Post a picture of the label on the ECM. I doubt your CEL is related to the oil, that's likely just a coincidence. Yes a Rhinda product is what is typically used to read codes, read ECM sensor data, clear codes and things like that.
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      Codemate should clear it out. Are you sure the oil pressure senser isn't bad? I had one go out and had to replace it. Easy and cheap fix.
