I'm considering performing maintenance on our 2016 G23 (with the XR7 engine) myself this winter as I have the opportunity to store it at a friends barn. This would be my first time doing any of the service on our boat, so could use this group's input
I got a lot of valuable info from this video (and other searches) and this is what I've gathered as my TODO list:
At the moment, I'm not planning on pulling the engine drain plugs or running anti-freeze as I'll be storing it along the west coast and the lowest temp on record in that city is 39, so it's unlikely to get below freezing (especially in the barn), but open to it if others feel I should do it.
Questions for this group:
- Check Transmission Fluid / Potentially Replace
- Replace Fuel Filter
- Add Fuel Stabilizer
- Clean Out Fuel and Water Separator Replacement
- Oil Change
- Unplug batteries
- Replace 4 impellers (planning on doing this in the spring)
- Am I missing anything? Anything I should be considering?
- I'm also trying to figure out the full part list (including recommended oil), so if anyone has this, I'd appreciate it
- Off-topic, but I've never towed the boat this distance (it'll be close to 6 hours)...any guidance, recommendations? I just wanna make sure I take the right routes, inspect the trailer, etc.
