I am debating on installing a NSS system on my 2012 210. And if anyone has done it was it worth the money and how was the installation process. I am looking at the NSS kit from Nautique so I can control it from my LINC system. Thank you,
Tags: None
1 post with a picture but no info regarding install, and worth spending the 4K to have it installed so hoping someone gives some feed back
https://www.planetnautique.com/vb5/f...install-thread
you won’t have to worry about the switch , because your Leno plugs with go to your Linc system.
it’s a very straight forward install . If you’re comfortable drilling a bunch of holes in your gelcoat. The “pucker” factor is higher than than the difficulty
I did the install on my 09 210 and absolutely worth it. Pretty straight forward install and works very well when dialed in.2009 Super Air Nautique 210 TE
1989 Sport Nautique
