Hi, what are the advantages/disadvantages of going PiggyBag over the oem hard ballast VS switching the whole thing for wakemaker ful size bags (1100lbs). To my understanding, the combined weight is pretty close plus you get to have your fill/empty gauge still fonctionnal right ? On a 230SANTE
For me it was storage and ease of maintenance , I have to carry 3 surfboards, and 3 wakeboards in my boat when I tow. , I also leave and lock my board in my boat down at our pier and lift. Lots of people always talk about the gauge and how valuable it is. Myself. I don’t see the value. My tanks would either be full or empty. 1 click of button is full . Simple as that.
I also get the appeal of keeping the boat as factory as possible .
there really is no right or wrong.Last edited by swatguy; 09-27-2023, 11:21 AM.
- Jun 2016
- 541
- Ft Worth, TX
- 2022 G23, Previous: 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
The piggyback system is just more finicky. And while you keep your gauges, they only read what’s in the hard tank. Because of the shape of the 2013 and earlier 230 hard tanks sometimes my piggyback bags would slide back and not fill all the way. Every now and then they wouldn’t empty properly. Also, without the hard tanks engine access is a lot easier for winterization. And if you’re that concerned about the gauge there’s a post on here for how to keep it with a little extra plumbing. Nothing wrong with a piggyback but on the older 230s removing the hard tank is a better solution. The newer tanks are shaped differently and are a lot more piggyback friendly so it’s not as clear cut on those.
Originally posted by hal2814 View PostThe piggyback system is just more finicky. And while you keep your gauges, they only read what’s in the hard tank. Because of the shape of the 2013 and earlier 230 hard tanks sometimes my piggyback bags would slide back and not fill all the way. Every now and then they wouldn’t empty properly. Also, without the hard tanks engine access is a lot easier for winterization. And if you’re that concerned about the gauge there’s a post on here for how to keep it with a little extra plumbing. Nothing wrong with a piggyback but on the older 230s removing the hard tank is a better solution. The newer tanks are shaped differently and are a lot more piggyback friendly so it’s not as clear cut on those.
