Speedo Calibration
  • Johnsongc
    • Jan 2004
    • 85
    • A, A
    Speedo Calibration
    I had to install a 2002 Teleflex speedometer in my 2001 Ski. The reading is at least 2mph slow. Does anyone know how to calibrate the speedo? I have a hand-held GPS that I can use for actual readings.
    Thanks,
    Greg
    '01 Ski Nautique
    '93 Barefoot Sanger
    '01 Sun Tracker
  • Johnsongc
    • Jan 2004
    • 85
    • A, A
    I tried to change the deviation settings but had no luck in adjusting the speed. Any thoughts?
    Thanks,
    Greg
    '01 Ski Nautique
    '93 Barefoot Sanger
    '01 Sun Tracker
    • skinautique
      • 1749
      • Colorado
      Send a PM to Frost. He will get it answered for you!
      • Johnsongc
        • Jan 2004
        • 85
        • A, A
        Will Do.
        Thanks
        '01 Ski Nautique
        '93 Barefoot Sanger
        '01 Sun Tracker
        • TURBOURBO
          • Feb 2004
          • 84
          • Atlanta
          I think if you use a GPS device, you can calibrate your speedos by watching the speed indicator. It's a pretty accurate method of setting the speedos.
          • Johnsongc
            • Jan 2004
            • 85
            • A, A
            Yeah... great... thanks. I guess there is no deviation or changes to the read-out. On the 2001 teleflex gauges you could, from the competition mode, adjust calibration by pushing the up & down arrow simultaneously and then add or decrease the read-out, i.e. adjusting the calibration. That does not seem to be the case with the 2002 gauges, but thanks for the "help"
            -Greg
            '01 Ski Nautique
            '93 Barefoot Sanger
            '01 Sun Tracker
