I have a 2002 Sport Nautique and it is my first time winterizing. I followed all the steps outlined in the great article for winterizing your boat. The one point in the manual and article states you should empty water out of transmission cooler. I have only found one screw for a small hex head bit at the bottom of my transmission. I believe that is most likely for draining the transmission fluid and not water. I have pumped antifreeze into the motor because it will be sitting outside shrink wrapped in my driveway for the winter.
Can anyone help with the direct drive transmission question? I saw it was posted many times but never answered. I have also tried to find images of the bottom of a PCM 1.23:1 transmission and came up with nothing.
Thanks!
Thanks!
