Winterizing Direct Drive transmission
  • tgrizz
    • Jun 2023
    • 10
    • Ontario
    I have a 2002 Sport Nautique and it is my first time winterizing. I followed all the steps outlined in the great article for winterizing your boat. The one point in the manual and article states you should empty water out of transmission cooler. I have only found one screw for a small hex head bit at the bottom of my transmission. I believe that is most likely for draining the transmission fluid and not water. I have pumped antifreeze into the motor because it will be sitting outside shrink wrapped in my driveway for the winter.
    Can anyone help with the direct drive transmission question? I saw it was posted many times but never answered. I have also tried to find images of the bottom of a PCM 1.23:1 transmission and came up with nothing.
    Thanks! Click image for larger version
  • Rednucleus
    • Jul 2022
    • 180
    • WA
    Draining the cooler, not the transmission. Follow the line from the transmission up to the cooler
    • mpost
      • Jun 2007
      • 139
      • Monticello, MN.
      • 98 SN GT40
      Your Trans. cooler should look like the one in this link,
      Between the raw water intake and the RWP. I usually vacumn that hose out from the RWP end to drain the hose and cooler.
      https://nautiqueparts.com/cooler-tra...t-pcm-r147014/
      1998 SN GT40
      84 2001 Ski Nautique (sold)
      Monticello MN.
