Have problems with my 2001 gt40 started with just shutting off when in use wait 10 minutes and would start back up run fine for sometimes up to two weeks, anyhow to make long story short the boat does not run currently fires but does not keep running, the fuel pumps have no power going to them? I have replaced low pressure pump, relays, diodes had the ecu checked and still getting same results, just need advice on what to check for next any suggestions??
Did you check the lanyard connection? The lanyard will kill the fuel pump power if disconnected.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
