98 196 shows no power
  • Calisdad
    • Jul 2017
    • 20
    • Dallas, Oregon
    • 98 Ski Nautique
    My boat driver hit a stump at 36mph. The boat took on some water, ankle deep in the boat when level. The boat has been repaired, but when I try to start it with a fully charged battery it doesn’t show any signs of life. No power from the battery. Got any ideas where to start looking?
  • MN Ryan
    • Aug 2020
    • 1261
    • Maple Grove, MN
    • 2007 SV-211 TE
    A stump at 36? Yikes.
    • Calisdad
      • Jul 2017
      • 20
      • Dallas, Oregon
      • 98 Ski Nautique
      There’s nothing more heartbreaking than watching your boat launch 2-3’ out of the water! Ripped everything off under the boat!
      • jkallen21
        • Jan 2013
        • 399
        • United States
        • 2006 Super Air 220
        Still friends?
        • MN Ryan
          • Aug 2020
          • 1261
          • Maple Grove, MN
          • 2007 SV-211 TE
          Or married?
          • jpwhit
            • Aug 2016
            • 533
            • Cary, NC
            Who repaired the boat? Why didn't they get it completely running?
            In terms of answering your question, there isn't enough detailed info in your post to offer much help.
            • SilentSeven
              • Feb 2014
              • 1867
              • Bellevue WA
              • 2004 Nautique 206
              How long has it been parked? Did the engine run after the impact? How about the trans? I'm going to assume it's been parked for a while for hull repair.
              Assuming the engine ran after the impact and there was no fatal internal damage to the trans or engine, I'd look at the starter and solenoid.
              If they got dunked in bilge water and then sat for an extended period, it's possible they froze up.
              If it was my boat...I'd do the following. Change the engine oil and trans fluid. Pull the plugs and put a little oil in each cylinder. Then hand roll the engine over to verify no interference and it's not frozen. Pull the starter and have it bench tested at a local auto parts store. Replace if needed and then try to start.
              Good luck. Let us know what you decide to do.
              Sent from my Pixel 7 using Tapatalk
              Bellevue WA
              • Calisdad
                • Jul 2017
                • 20
                • Dallas, Oregon
                • 98 Ski Nautique
                Still married….barely. No water in engine or transmission oil/fluid. It’s something electrical. I’m not sure if there’s a main circuit breaker or fuse that could have gotten water in it and is no longer conducting ? The radio or blower or anything electrical is getting energized
                • bturner
                  • Jun 2019
                  • 1577
                  • MI
                  • 2016 200 Sport Nautique
                  I believe there's a 50 amp breaker located on the motor that I had randomly get set. Boat was completely dead. I would start there then move on to the breaker panel working from the battery input to the panel. If no power to the panel, trace back to the battery and start from there.
                  • bturner
                    • Jun 2019
                    • 1577
                    • MI
                    This is what it should look like. They move them around but you should get the picture (pun intended) by this....
                    • fsts2k
                      • Nov 2004
                      • 215
                      Sorry to hear, hope everyone was ok.
                      Do you know if the fuel pump is getting energized at all? If it is a GT40 it should run for a few moments prior. I had an issue with my ECU which caused the fuel pump to not run although my starter would still fire.
                      Have you checked power at the starter with a multi-meter when the key is turned?
                      • Calisdad
                        • Jul 2017
                        • 20
                        • Dallas, Oregon
                        • 98 Ski Nautique
                        I truly appreciate you folks! It was a circuit breaker for the ignition!!!!
