No crank push button start won’t light up ignition any help
Tags: None
skiwhite@cox.net If the little light on the keypad is not coming on, it is likely that the keypad itself has failed.
NautiqueParts has them, and they aren't too bad to change out. You need to remove the dash, and then it is just a couple of small nuts that hold the keypad in place.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
The push button start green light comes on but when you push the button, the ignition doesn’t come on we’ve replaced the Killswitch and the keypad any help
Should be two little lights on. One on the right and one on the left. Are they both on?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
The light on the right lights up. The light on the left, does not light up after putting in code And then the ignition will not light up
I would bet that the keypad is at fault here.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Are you pressing the start button enough times? First press - one light should come on. This is equivalent to "accessory" on an old style car key switch. 2nd Press the 2nd light should come on, this is equivalent to "ignition on" on an old style car key switch. 3rd press is "Start".
You've replaced the keypad once or twice? Assuming once, how long did it work properly once the keypad was replaced?
I'm with NautiqueJeff, if the 2nd light on the keypad isn't coming on, then I don't know what could be wrong other than the keypad. If you just replaced it, and it's not coming on, then it sounds like you got a defective one.
You can send the keypad to Nautique and they'll test it for you.
