2006 Nautique 210 Compression Test Results
  • Leemer
    • Feb 2024
    • 15
    • Seattle, WA
    The 2006 is supposed to be without pitot tubes running to the gateway and the video shows the gauges working exceptt for the temperature gauge and speed, presumably because the boat is on land. I hear you, that the gauges have been a big issue on this generation, but the second video appears to indicate they all work except for the analog temperature gauge. The digital temperature gauge within the electronic display in the RPM gauge is working. Does anyone know if the analog temperature gauge could be repaired?
    • core-rider
      • 1350
      • Huntsville, AL
      • 2003 Black SANTE
      It could be as simple as the wiring came unplugged from the back of the gauge. The fact that it’s well below the lowest temp reading makes me think that could be the case. I don’t believe mine goes that low even with the boat powered down. It’s not the end of the world since the digital readout still shows your temperature. Kinda odd they didn’t look like they were working in the other video.
      He’s correct though… speedo will not work unless the paddle wheel is spinning or the pilot tubes are reading pressure. Also the 7.2 he was confused about is a calculation of fuel consumption. For some reason it’s displayed as liters per hour instead of gallons. Mine is the same way, but I don’t care about fuel economy!
      Overall it looks like a decent purchase other than the filthy interior.
      Jason
      All black 2003 SANTE
      -- Southern Fried --
      • Leemer
        • Feb 2024
        • 15
        • Seattle, WA
        Thanks you! They are spending today and tomorrow detailing the boat. I expect it will look only slightly better. I guess that gives me something to do when I get it.
        • bturner
          • Jun 2019
          • 1577
          • MI
          • 2016 200 Sport Nautique
          Last thing to take a look at..... Get the date codes off those shinney tires and see how old they are. Past 4 years and you're going to need a new set. Tread and/or sidewall condition doesn't matter as tires will rot from the inside out sometimes. Before you blow off tires as being cheap, Goodyear Endurance 15" tires are $180 a piece here in Michigan and you'll need 4 of them. Adds up quickly.
          The trailer is something a lot of people overlook when buying a boat then end up spending big afterwards. Also pull the cap off the master cylinder and look at the brake fluid. First see if there's any in there. The last 3 boats I looked at for friends, there wasn't. I like to take a piece of paper towel and dip it in the fluid (if there is any) to see what color it is. Most times if there is any, it's a dark brownish rust color. The fluid is supposed to be changed every 2 - 3 years but rarely gets done by most owners.
          I know this seems nit picky but if you're in CA you'll probably be towing in hot weather. Nothing like sitting on the side of the road in 95 degree weather.
          • Warrior48188
            • Aug 2017
            • 23
            • Michigan
            • 2004 SAN
            Nice boat. Love the color scheme, but I might be a bit biased. Most SAN's under 30k will require a few repairs. The missing transom cups are $32/ea and take all of 5 minutes to install. The boat interior looks like it has seen a lot of sun (Havasu). You can see the interior starting to split (back side of the starboard engine hatch cover). Most boats in this era will need a new interior. I replaced mine a few years ago for under 5k.
            • Leemer
              • Feb 2024
              • 15
              • Seattle, WA
              #21
              All great points. I'm in Seattle and I'm a trailer snob so all of these things will be on my to do list. I was happy to see it had disc brakes. It was kept at Lake Arrowhead. It's a one owner boat and comes with two covers. The owner purchased another new SAN from the dealer, hence the trade. I used to be a mechanic and would love to teach my eight year old son some skills. Flushing the brake fluid is a great suggestion. I bet it is original.
              • Leemer
                • Feb 2024
                • 15
                • Seattle, WA
                #22
                I share your concerns on the interior but was surprised to see that I could buy individual pieces, although matching might be an issue, from C & S. I reached out to them and they provided the following quote. I asked the dealer to do a piece-by-piece inventory and tell me if there is cracking, tears, stains or damage. Here is the quote I received:
                The replacement upholstery skins for the listed boat are:
                2003-2006 210 Super Sport/ Air
                UPDATED 6/22
                Complete set, 21 pieces standard hatch - $5553
                Complete set, 21 pieces python hatch - $5677
                Coaming pad, port- $254
                Coaming pad, starboard- $283
                Bow bottom, front- $195
                Bow bottom, Port- $195
                Bow bottom, Starboard- $159
                Bow backrest wrap w/logo- $705
                Bow bottom, filler- $147 (optional, not added in)
                Walk thru wall, with carpet, port- $71
                Walk thru wall, with carpet, starboard- $71
                Driver seat bottom- $187 (add $52 if a flip-up)
                Driver seat Arm wrap- $468
                Driver seat backrest- $159
                Observer seat bottom- $225
                Observer seat backrest- $250
                Arena seat, port- $190
                Stern seat backrest w/logo- $619
                Stern seat bottom port- $223
                Stern seat bottom starboard- $223
                Stern seat bottom center- $206
                Hatch, Port- $227
                Hatch, Starboard- $227
                Hatch center- $416
                OR For Python engine Center hatch $540
                OPTIONAL Carpet 102"x10yds - $575
                • SilentSeven
                  • Feb 2014
                  • 1868
                  • Bellevue WA
                  • 2004 Nautique 206
                  #23
                  Smart to factor in upholstery costs. You can do it all in a single hit or on an as needed basis. If you're handy, you can self install many skins yourself.
                  I'm also in the Seattle area and have self replaced several skins using C&S products with good results. If you go down that road, happy to share what I have learned.
                  Sent from my Pixel 7 using Tapatalk
                  Bellevue WA
