Help rubber 1 inch fall inside v drive on filler plug
  • Rush111
    • Mar 2024
    • 2
    • Oman
    I was trying to change oil fluid of v drive using extractor through the filling plug the rubber hose stuck inside when I pull it got stuck inside got cut inside
    1/half inch left inside the v drive what to do now ? Shall I run the boat and get it smashed chewed inside?
  • hal2814
    • Jun 2016
    • 541
    • Ft Worth, TX
    I don’t know what v-drive you’re dealing with but none of them are going to like a piece of rubber in there. If you can’t get it all out with something like a metal pick, you’re going to have to disassemble the v-drive enough to get it out. With the older units like a Walters that should be doable while it’s still on the boat. If it’s a newer one like the PowerPlus, you may need to remove the v-drive and crack it open.
    • jpwhit
      • Aug 2016
      • 533
      • Cary, NC
      Absolutely, do not run the v-drive with a piece of rubber inside. That isn't going to end well. Pieces of chewed of rubber will clog every valve and passage in the transmission.
      You may want to try a boroscope to get a better idea of where the piece is at the moment.
      • Rush111
        • Mar 2024
        • 2
        • Oman
        It’s newer power plus v drive
