1998 Correct Craft with 5.8 PCM Surging while Idling and excessive smoke from exhaust
  • LouShaw
    • Sep 2023
    • 18
    • Rogers Arkansas
    • 1998 176 Correct Craft
    Boat has new plugs and fresh oil at the proper level.
    Any guidance would be appreciated! Thanks
  • jpwhit
    • Aug 2016
    • 533
    • Cary, NC
    Possibly bad valve guide oil seals, or blown head gasket. What color is the smoke?
    • LouShaw
      • Sep 2023
      • 18
      • Rogers Arkansas
      Thanks for the response. Grayish smoke
      • Jonny Quest
        • Aug 2014
        • 383
        GT40 engine or carbureted? If GT40, a surging or "loping" idle is a known issue. Replacing the Idle Air Control valve, Manifold Absolute Pressure sensor and Throttle Position sensor usually fix the loping idle. All these parts are Ford / FoMoCo and you don't have to buy PCM parts that are waaaay too expensive. Another known problem is the fuel pressure regulator. These parts are fairly easy to replace and you don't need a PhD in internal combustion engines to figure it out.
        If you have a carby engine, dark gray / grey smoke can be an indication of an overly-rich air/fuel mixture.
        lease provide additional details.
        JQ
        • LouShaw
          • Sep 2023
          • 18
          • Rogers Arkansas
          Thanks JQ. The engine is a 351 W I imagine some of the same issues may cause problems as the GT40
          • LouShaw
            • Sep 2023
            • 18
            • Rogers Arkansas
            It has a Holley Carb
            • Jonny Quest
              • Aug 2014
              • 383
              OK...dark gray smoke can be a sign of a carb out of adjustment. When was the carb last re-built? At idle, remove the spark arrestor and look down the throat of the carb. Can you see fuel dripping?
              • LouShaw
                • Sep 2023
                • 18
                • Rogers Arkansas
                I will try this. My brother and Took the carb off and cleaned it. I bought the boat last spring and I dont know if its ever been rebuilt. Its mostly sat most of its life. It had less than 200 hours on it when I purchased it.
