2006 Nautique 226 - Why No 'Clunk' From Transmission?
  • Rusty Axle
    • Nov 2023
    • 74
    • IN
    • 2006 Air Nautique 226 Team Edition
    This is my first experience with an inboard.
    I'm accustomed to a 'clunk' when putting a boat into gear.
    The Nautique is quiet as a mouse.
    Why is that?
  • Jonny Quest
    • Aug 2014
    • 383
    That "clunk" you are used to is likely from an I/O or outboard, correct? The inboard transmission is more like a car transmission...quiet and smooth. If there is some chatter or rattling from the transmission, the damper plate is a likely culprit. In reverse, the PCM transmissions are often referred to as a sewing machine sound.
    JQ
    • jpwhit
      • Aug 2016
      • 533
      • Cary, NC
      Because inboard transmission have hydraulically activated clutches. I/O transmission are much more primitive and actually just move two gears or cones together. So when you're putting an I/O into gear, you're hearing the gear or cone teeth bang together until the gears are fully meshed.
      • Rusty Axle
        • Nov 2023
        • 74
        • IN
        Thank you! I appreciate the responses.
        • SilentSeven
          • Feb 2014
          • 1867
          • Bellevue WA
          • 2004 Nautique 206
          There's a reason these transmissions are branded "velvet drive"
          Bellevue WA
          • poecs13
            • Oct 2017
            • 23
            • Dallas, TX
            • 2015 Ski Nautique 200 TE 6.0L; 2005 Ski Nautique 206 6.0L (Sold in ‘23)
            Just wait until you try a DBW transmission, circa 2013 or later. I just traded my 2005 for a 2015 last summer and shifting is smoother than butter!
            • Rusty Axle
              • Nov 2023
              • 74
              • IN
              That is good to know.
              The 2006 226 that I picked up gives no indication of gear engagement whatsoever. Forward or reverse, there is no indication of a gear engagement. It's as if I'm dealing with throttle only.
