2017 G21 Ballast King Pump Issue
  • QKAG21
    • Jun 2018
    • 34
    • NY
    • 2017 G21 2019 Ski Nautique
    Hello, we have a 2017 G21 that
    has the Jabsco Ballest King pumps.
    They are installed with the pump on top.
    We have had 3 go bad, and we are wondering
    if it is a known issue.
    The seal leaks because of gravity.
    We are also looking to get new seals.​
    Any advice would be appreciated. Thanks.
  • MN Ryan
    • Aug 2020
    • 1261
    • Maple Grove, MN
    • 2007 SV-211 TE
    You're saying they're installed with the pump head above the motor? My BIL has had that same issue with his Mastercraft--they were installed in that orientation. I am pretty sure when he replaced the last one, he flipped them over.
    • QKAG21
      • Jun 2018
      • 34
      • NY
      Exactly. There are three pumps, two have the pump housing above the shaft, as several have gone bad, several times. The center ballast pump is horizontal, and has worked for 7 years, We now rebuild the motors, rather than buy new at 400.00 per. I am also wondering is the winterizing fluid is overly corresive to the pump.
      • MLA
        • Dec 2009
        • 1312
        • Lake Wylie NC Area
        Huh! Run the pump in reverse for 5 seconds and its winterized! No fluid needed!
        But yes, its a know issue to mount the pump so the pump head is above the motor, which is why the pump manufacture advises against it.
