Boy, I hope someone can help.
Problem: Loss of antifreeze within the closed cooling side of the engine (2007 ZR6 6.0L PCM). Nothing is leaking externally
What is happening: I fill the reservoir and drive for a bit (under an hour). engine temp comes up. I have to stop and add more antifreeze.
What I have checked: I checked the oil to see if antifreeze was going into the engine. All perfect. I checked the plugs, all perfect and the engine runs perfect. I took the heat exchanger off and to a shop to be cleaned and tested thinking that has to be the problem. It checked out fine
So now I'm thinking about the exhaust manifolds and the risers.
Question: Is there any antifreeze running through the manifolds or the risers? Externally I see no hoses (other than raw water) that attach to the manifolds externally. Could there be block antifreeze somehow circulating through the manifold/riser that has a leak and causing loss of fluid which then is going out the tail pipe??
Lastly. I have records that the manifolds were replaced before and about a year ago I replaced the gasket between the top of the manifold and the riser but I don't recall seeing antifreeze there.
Ask more questions please if I haven't provided enough info
And IF there is no antifreeze going through the manifolds/risers then what in the world could be happening?
Best regards
Don in Vegas
Best regards
Don in Vegas
