25 hour service for new motor replaced under warrantly
  • bkoughan
    • Apr 2024
    • 2
    • MN
    • 2018 G21
    The dealership billed me for a 25-hour service on a motor that was replaced under factory warranty last summer. Seams like I shouldn't have to pay for a second 25-hour service on the same boat. It might feel differently if they extended the warranty on the replacement motor but they apparently don't. I just got the invoice and have not had time to contact them but I'm curious what I should expect them to say when I push pack on it. Thanks in advance!
  • core-rider
    • 1350
    • Huntsville, AL
    • 2003 Black SANTE
    Considering you're paying for a service on the new engine and not the boat in particular, I'd say they are completely justified in the charge. 25 hour service isn't covered under warranty so you're on the hook for that. Unless the dealer decides to be helpful considering this engine was a warranty replacement and decides to comp you the 25 hour service fee, then I wouldn't expect much from them... and considering they have billed you for the service I doubt they will change their mind and comp you. Good luck though!
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • GMLIII
      • May 2013
      • 2797
      bkoughan
      IMHO I would be more concerned with getting dealer to cover loose fittings , hose leaks , fiberglass gel coat ding repairs from engine install vs 25 hour service charge . I had to pay the 25 hour service fee on my 2017 G23 after I purchased it
      • bkoughan
        • Apr 2024
        • 2
        • MN
        • 2018 G21
        GMLIII
        I haven't had any issues with the gelcoat or loose fittings but I do have noisy rockers that they are investigating. It sounded like it's not the first time the tch has seen that issue. Thanks for your comments.
