A slow start this year, but the weather has been far from conducive.
There is a lot of storage on these rigs, you don’t realize until you start hucking stuff over the sides.
It’s like a little circus car, the clowns keep coming out.
I put together a Spring checklist, I know I probably forgot something, but I’m sure it will get done in the process. Anyone see anything crucial that I missed?
Pre-season Checklist (non-winterized climate-controlled storage):
~Scooter
- Trailer inspection, light check, brake fluid, check air pressure & spare.
- Sealed bearings, good for a few more years. Brake pad inspection.
- The Fulton jack is getting just a little tight. I’ll give that a little attention.
- Engine maintenance, change oil/filter, impeller change, belt & hose inspection, fuel filter, check & clean intake screen, top off trans fluids, clean spark arrestor, cap & wires inspection. I might change plugs next year or at least inspect and run a compression check for a base line (currently 450ish hours).
- 3 new ballast pump impellers last year.
- A little grease on the rudder zerk.
- Battery charge (been on & off the trickle all Winter), cables inspection.
- Soap blast & power wash trailer & rims.
- I detail the trailer once a year, that means buffer & wax. My least favorite thing to do.
- Gel scratch repair, buff & wax.
- Beverage & chip break x 3.
- Yard sale everything out of the boat. Inventory what you think you have, and what you had forgotten you had.
- Vacuum all lockers & boat. Scrub and rinse interior.
- Clean & condition upholstery.
- Window shine last.
- Inspect & test all components of boat, lights, linc screen, etc.
- Inspect & clean boards, check bindings & fins, surf board pads & fins.
- Slap this year’s reg tags on (Red this year). Trailer tags, good for a few more years.
~Scooter
