Hey All, I have a 1987 Nautique with a 351 PCM and am looking to fix an incorrect oil pressure reading. Looking for some help identifying the smoking gun.
BLUF:
1. Ignition on, engine off, gauge reads 60. (gauge is 0-80)
2. Turn engine on, gauge pegs at 80.
3. Remove sending unit from block, with wire attached, gauge reads zero, when sending unit is grounded to the block the gauge reads 60.
4. The oil pressure read at the block with a dial gauge reads 30psi when warmed up.
Any ideas where to start?
BLUF:
