Manifolds and Risers
  • Spud
    • Jul 2006
    • 218
    • Echuca Australia
    • 2007 206 limited 2008 206 limited 2007 196 se 2010 200 team
    After some help on Exhaust Manifold and riser torque specs … for our 2008 Nautique 210 with EX343.
    Pulled them today ( with the help of my 9 year old son) to check condition and need to reinstall .
    Cannot find the correct torque specs for the manifolds or risers anywhere…
    Intend to reinstall with some type of anti size product so that may effect torque values?
    Your help would be appreciated!
    ​ image widget
  • SteveDoc
    • Nov 2012
    • 29
    • The Pond and Sacramento Delta
    • Redwood city ca
    • 2002 Ski Nautique 196
    I changed my manifolds and risers 3 years ago on a 2002 with the 330 engine. I used Remflex gaskets, I believe, torqued the manifolds to 22 foot pounds and the risers to 25. The gasket company said 20 but I did the 22. Also to make it easier to install the manifolds I got 2 longer bolts cut the head off and hacksawed a slot in the end screwed in those and then slid the gasket and manifold on installed other bolts removed modified ones and installed remaining 2 and torqued all. Have had no trouble. Have fun
    • Spud
      • Jul 2006
      • 218
      • Echuca Australia
      Thanks that is much appreciated. Did you happen to use any anti seize on the manifold and riser bolts ?
      • SteveDoc
        • Nov 2012
        • 29
        • Redwood city ca
        No didn’t use any anti seize all the bolts came out real easy. Also didn’t retorque any bolts after running boat per gasket maker.
