Noise
  • GMLIII
    • May 2013
    • 2797
    Noise
    I have a noise only when my boat is in neutral after coming off plane and it sounds like a pulley getting ready go out. My question, do you think this might be the idler pulley getting ready to fail? I think this particular pulley has been known to fail on these G23s. Again, the noise only occurs while boat is in neutral.
  • bturner
    • Jun 2019
    • 1578
    • MI
    • 2016 200 Sport Nautique
    Do you have a long screw driver and safe access to the front of the engine? If so you can use the screw driver to pin point the sound of a failing bearing. The key here is safe access and being very careful when doing this. My father taught me this when I was like 12 so this is a very old school technique from back before when kids worn helmets to play on the swing set....
    https://www.youtube.com/watch?v=QvG9K95vFDY
    • srock
      • Oct 2008
      • 1068
      My son of a mechanic father taught me the same thing. They actually make and mechanics stethoscope for this purpose...$8 bucks at harbor freight.
      • GMLIII
        • May 2013
        • 2797
        My gut is telling me , it is probably a raw water pump bearing getting ready to fail.
        Bearing Housing Assembly 5.7/6.0/8.1 - Nautiqueparts.comโ€‹
        • Scooter G
          • Jan 2022
          • 1320
          • On a Lake in Idaho
          • 2022 G23 ZZ8
          Great hack bturner.
          I picked up one of these a season or 2 ago, it's paid for itself already. Mostly with neighbors & friends.
          I'm not a Doctor, but I paly one on TV (some of you will get that one).
          Click image for larger version  Name:	Probe.jpg Views:	0 Size:	35.2 KB ID:	676156
          https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
