Transmission Fluid Change G23
  • Scooter G
    • Jan 2022
    • 1320
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    Changed out the Transmission Fluid Thursday after we pulled the boat out from a lake run.
    I’ve mentioned it before, but the must have here if you are changing your own fluids is a pressurized oil extractor. I use the 2 Uncles Extractor and it comes with a multitude of different size lines and attachments – Not affiliated and have nothing to compare it to.
    Fluid was hot and came out super-fast with just a few pumps on the extractor. This is the 1st time I have done this, and felt around a little with the extractor hose to make sure I was on the bottom of the trans. I refilled at 1 ½ quarts, and then measured how much was extracted, 1 ½ quarts. The manual indicates 2 quarts, which means I left 16 ounces behind, hmm. Next time, I think I will run a smaller hose to see if I can’t get in a little deeper and measure the output. Open to suggestions if anyone has some thoughts here. In my mind 1 /12 quarts of fresh fluid is better than none.
    Dealer says they did a change out 2 seasons ago with Dexron VI, but that fluid looked pretty dark to me for only 2 Seasons?
    Next time, a little time on the shop vac followed by some air pressure, definitely not the cleanest area in the boat.
    Click image for larger version  Name:	1.jpg Views:	0 Size:	111.6 KB ID:	676307
    Click image for larger version  Name:	2.jpg Views:	0 Size:	94.7 KB ID:	676308
    Click image for larger version  Name:	3.jpg Views:	0 Size:	293.6 KB ID:	676309
    Pretty straight forward
    Click image for larger version  Name:	4.jpg Views:	0 Size:	243.8 KB ID:	676310
    Wasn't sure which funnel was going to fit the bill, but the adjustable measured unit in the middle was by far the best choice.
    Click image for larger version  Name:	5.jpg Views:	0 Size:	122.6 KB ID:	676311
    The extractor measure out at 1 1/2 quarts, so I figured out that is what needed to go back in.
    Click image for larger version  Name:	6.jpg Views:	0 Size:	100.1 KB ID:	676312
    Top of the full mark, measured without screwing cap down (as per manual)
    Click image for larger version  Name:	7.jpg Views:	0 Size:	157.4 KB ID:	676313
    Left some fluid and the funnel in the engine bay. Will check levels again on warm up next trip out.
    Click image for larger version  Name:	8.jpg Views:	0 Size:	312.3 KB ID:	676314
    Double checking measurement accuracy of the extractor, and visual inspection of the fluid.
    Click image for larger version  Name:	9.jpg Views:	0 Size:	109.2 KB ID:	676315
    Yup, 1 1/2 quarts. Does that fluid look a little dark to you?
    Click image for larger version  Name:	10.jpg Views:	0 Size:	105.7 KB ID:	676316
    Manual Instructions .pdf of the process:
    G Trans.pdf
    I hope this helps someone, easy to tackle yourself. Let me know if I missed something, always willing to learn and/or make things easier.
    ~Scooter G.
  • Lockem25
    • Oct 2021
    • 54
    • Kentucky
    • 14 g23
    Easy enough, I just did mine while the floor was out(New ballast pump for aftermarket bags install) definitely not the cleanest area but I dont expect it to be either.
    I was curious how bad it would be to get to with the floor in but it looks manageable!!
