No Water from exhaust after de-winterizing 5.7L
  • jpwhit
    • Aug 2016
    • 526
    • Cary, NC
    Originally posted by Scooter G View Post
    Not possible fins will correct their position on rotation, just saying. Probably not the best thing on longevity though...
    Depends on the pump. Some pumps will flip, and some won't.
    • Scooter G
      • Jan 2022
      • 1320
      • On a Lake in Idaho
      • 2022 G23 ZZ8
      You might be right, come to think of it, not sure my Supra would of flipped. The shaft design was not centered, which put the vanes on one side of the case tight, almost flat. Difficult coming out, miserable going in.
      • jmo
        • Mar 2006
        • 707
        • MA
        When you run with perks switch or a water hook up, make sure the seacock for the pick up off the bottom of the boat that normally feeds the strainer is closed, otherwise you could be losing water and pressure out the bottom…. And of course don’t forget to open it after your done!
        2018 Ski Nautique 200 TE, H6
        • KDenning
          • Aug 2023
          • 36
          • South Lake Tahoe California
          • Click image for larger version
ID:	676447My mechanic diagnosed our issue as needing a new raw water pump. That’s well-supported on the Facebook group if you search “water pump.”
          • CarlitosAir
            • Jul 2022
            • 35
            • TX
            • 2006 air nautique 226 team
            guys... thanks for you all's responses. I had let my brother install the FakeALake, and he put it on poorly, leaving an air gap in the "plunger" part. This was confirmed because I tested the boat after installing the plunger myself, VERY carefully, and worked just fine from the get go. Either way, freaked me out, and the responses here assured me it was a poor install causing the loss of vacuum. Ended up putting on a new impeller.
