Lost a fin
  • pfegan11
    • Oct 2020
    • 11
    • Pittsburgh
    • 2003 SANTE
    Lost a fin
    Just hit a mini log and it ripped a whole fin out. Do you think I could get new screws and some rubber washers and salvage the weekend?
  • hal2814
    • Jun 2016
    • 541
    • Ft Worth, TX
    If you’re just looking for a temporary fix, just get a tube of 5200 and fill the holes. You’ll probably have to re-drill them anyway when you get a new fin.
    • pfegan11
      • Oct 2020
      • 11
      • Pittsburgh
      • 2003 SANTE
      Yeah just looking to boat this weekend, so a temporary fix until the new fin comes in
      • jpwhit
        • Aug 2016
        • 526
        • Cary, NC
        Put RTV sealant in the holes to keep lots water coming in this weekend. If it leaks some, the bilge pump will take care of it.
        • jmo
          • Mar 2006
          • 707
          • MA
          You really need to let it completely dry out and at a minimum seal up the holes, otherwise if you get water in there it will get between the fiberglass and the gelcoat causing blisters over time.
          2018 Ski Nautique 200 TE, H6
          • SteveDoc
            • Nov 2012
            • 28
            • The Pond and Sacramento Delta
            • Redwood city ca
            • 2002 Ski Nautique 196
            If that happened to my boat I think I’d throw up.
            • pfegan11
              • Oct 2020
              • 11
              • Pittsburgh
              • 2003 SANTE
              So I tried just putting a new fin on with a lot of sealant but it wasn't water tight. Found out there is a trickle of water coming from the new fin area. Any suggestions for the correct course of action? I was thinking I need to find someone that does hull repair and have them redo the area and redrill new holes.
