Need advice on next steps to making 84' Nautique shine again
  • trueblue41
    • Nov 2023
    • 22
    • Indianapolis IN
    • 1984 Ski Natique Custom Craft 2001
    1984 CC Ski Nautique
    Been looking into restoring the shine to the Hull, and many steps I read about are as follows:
    1. acid wash (oxalic or muriatic if really bad)
    2. buff with oxidization remover (OR wet sand if really bad and want to sand out scratches)
    3. buff with polish
    4. buff with wax
    In the third image, you'll see the progress i made with some starbrite cleaner (still need to do more because of some remaining scum line).
    So i have some questions for next steps:
    My "decal" ("SKI NAUTIQUE" across the hull) appears to be negative-space where they tapped it off and painted the stripes. I think the only decal I actually have is the "2001" and registrations stickers.
    1. I only used oxalic acid on the water line & below... Can i use it on the painted stripes and and rest of the hull?
    2. Do I need to do full oxidization removal? I can't tell if my boat is actually oxidized and needs this or just needs polish/wax... and will this damage the stripes?
    3. Based on the above, is this someone a complete first-time-owner can/should do themselves? Or is it a "pros only" job?
Name:	Screenshot 2024-05-25 at 10.54.44 PM.png
ID:	676567 Click image for larger version
Name:	Screenshot 2024-05-25 at 10.54.53 PM.png
ID:	676568 Click image for larger version
  • aerojust
    • Jul 2020
    • 66
    • VA
    • 2020 SAN 230 Past 2000 Ski Nautique TSC1
    This guy does a full restore on a 87. https://www.youtube.com/@MakeSkiBoatsGreatAgain
    Also check this out https://www.youtube.com/watch?v=yJtd...e%27sDetailing
    Last spring we did a full wet sand and buff and polish on my buddies older moomba. It turned out great.
    To do it right you will need to remove any decals.
