Hello,
I am in the middle of swapping out my engine after doing a poor job of winterizing the boat. After replacing some core / freeze plugs and JB welding a cracked head I noticed the oil level was increasing and it was starting to turn a milky color after running the engine out of the water with one of those water plunger things. That is when my heart sunk and I called my self names for 2 hours. Time for a new engine.
I called a few places and here is what I found or think that I heard.
Eagle Engine Sales
Reman $3,200 ( reman in their factory and comes with harmonic balancer + water pump + tin )
New $5,200 (direct from GM long block and eagle sales adds a harmonic balancer + water pump + tin)
Marine Engines 4 less
Reman base $3,600 ( reman in their shop / assembly line. This also comes with tin + harmonic balancer )
New $4,650 ( I believe they assembling and engine from new parts using the DART block and parts shop / assembly line. This also comes with tin + harmonic balancer)
PCM authorized dealer in Sacramento
Reman from MerCruiser $4,800
New from MerCruiser $9,500 ( From what I understand they also use the DART block )
I decided to go with a new GM 5.7 from eagle engine sales and it arrives today.
Questions:
Thanks
-Derek
Eagle Engine Sales
Questions:
- Is there anything else I should be fixing or inspecting while I have the engine out? My steering is relatively smooth but could be better in my opinion. Is there something I can grease or fix there?
- damper plate - From what I read the damper plate can last 2500 - 3500 hours. Boat gauge shows 500, so unless its falling apart when I inspect it I am guessing I can re use it. Anyone have a different opinion?
Thanks
-Derek
