Hooked battery up backwards....
  • Repsol83
    • Jun 2024
    • 3
    • WI
    • 2000 air nautique
    Well I did something dumb and hooked my battery up backwards. 2000 air naiutique.
    It popped the 20amp glass fuse by the perko switch. If I replace the fuse I get power to the dash and blower, but as soon as you hit the start switch it pops the 20amp fuse again and kills power to the dash.
    The red 12.5 and 15 circuits on the back of the engine I can push the button, but the 60amp is stuck tight. It pops with or without the 12v relays plugged in.
    What else am I looking for? I don't see any other fuses between the starter and circuit breakers..... ugh!!!
    Any help would be great.....​
