2018 G23 Dies when put in gear
  • gundogg
    • May 2006
    • 91
    • Nor-Cal
    • On Order: 2018 G23 Current: 2006 SANTE
    Yesterday on our way in the boat died while slowing down to idle at a 5MPH zone. Restarted the boat and tried to put in gear... boat died again. This continued for about 6 times. As we drifted towards shore we were able to get the boat into reverse and it wouldnt die. Tried forward again and it would work. The boat is currently at the lake which is 5 hours away from the dealership. Not sure what to check next.
  • Rednucleus
    • Jul 2022
    • 177
    • WA
    • Club Boat 2014 Ski Nautique 200
    MAybe you had something stuck in the prop and reverse cleared the problem. Check the prop for debris; make sure you can spin the shaft as well.
