https://nautiqueparts.com/throttle-base-assembly/
Also fits SN 200 2019+
Systems: Random no starts, neutral lock out not working.
I found next to nothing out there when it comes to this replacement procedure.
I would like to give special credit to aerojust for taking the time to post the procedure on his thread, it gave me a great kickstart:
https://www.planetnautique.com/vb5/f...nd-replacement
Nautique Parts, ordered new base on Monday, showed up at my door Wednesday afternoon (regular shipping). Good job NP, and thanks for the "PND" 10% discount code.
Things you may need.
Trim removal kit
Christmas Tree studs
https://nautiqueparts.com/christmas-tree-studs/
Remove throttle center cap, it just pops out
3/16" Allen
Trim removal. Try to find a corner or area of easiest access. Once you've gotten the 1st tree to pop, just follow the path and try to get as close as possible to each tree with the tool(s). You have a few panels to pull...
Apparently, someone let Lucy have a sharpie at the factory, they should of known better.
Not much to the control pad, I was expecting more. Detach plug.
I would of loved to have been able to pull the seat cushion behind the drivers seat, better yet, I would love to know how?
A plethora of phillips screws surrounding the hard cover.
Man I've been wondering where those 2 bobby pins went, been looking for those for years.
A flexible extension, one of my top 10 tools, and it seems to get used on boats more than anywhere else.
Unplug base.
The red arrow on the right indicates a screw only, the other 3 have nuts. Reach in for a feel to see that yours is the same.
I went with a 10mm, but I think it's actually a 3/8". Didn't want to crawl back out of the boat.
Old base, dated 2016
New base, 2024
A like to throw a little dab of Dielectric Grease on the electrical connections
Assembly in reverse.
Word to the wise, remember to plug the safety lanyard back in before testing. I'll never get those 30 minutes back of what did I miss, fetch.
Neutral lock out works now, there is even a blue light on that thing, cool. All seems well on the test fire, we'll hit the water this evening for the final test.
I hope this deems useful in the future. With this outline, you should be able to tackle this in an hour, 2 people would be extremely helpful.
~Scooter G
Trim removal kit
3/16" Allen
Unplug base.
New base, 2024
~Scooter G
