2006 SV-211 Ballast no power on fill but drain works fine
  • Wes G
    • Jul 2021
    • 11
    • Marble Falls, TX
    • 2006 SV-211
    I have been troubleshooting all day. I have the basic SV-211 with only rear tanks and no keypad. When I flip to drain the pumps come on. When I flip to fill they don't. I tested at the pumps and I get no voltage on fill but 12 volts on drain. I saw discussion about relays, but I am not sure my boat has them. I can't find them. Any advice? Also I followed the jumper process to bypass the ballast control module and still no improvement.
  • bturner
    • Jun 2019
    • 1739
    • MI
    • 2016 200 Sport Nautique
    The electrical diagram for your boat can be found here.....
    https://www.planetnautique.com/vb5/f...iring-diagrams
    According to that you have a relay box that would appear to be in the port, rear area of the boat. If you have power at the switch, my money would be on a bad relay or associated wiring.
    • Wes G
      • Jul 2021
      • 11
      • Marble Falls, TX
      • 2006 SV-211
      Thank you! Found it. It's actually on the starboard rear port, and it's just a 20A fuse that somehow controls both pumps. Click image for larger version
ID:	678012 Click image for larger version
