Disconnected engine ground cable on 2006 SV211
  • Mahoo
    • Oct 2008
    • 27
    • Georgetown Texas
    • 2005 SV211 team
    Had a knock sensor error come up so looked into port side engine bay and found the knock sensor wire disconnected from sensor. Also found the reason was the engine ground cable was not connected to engine and lying on top of sensor wire. it's still connected to boat ground. The engine still starts fine without it but I want to get this fixed correctly.
    I don't see or feel an engine stud on the side of the block to reconnect it to. Does anybody know where to reconnect it?
    Thanks, Mitch
  • MN Ryan
    • Aug 2020
    • 1261
    • Maple Grove, MN
    • 2007 SV-211 TE
    Sorry, I'm of no help, but I kept wondering what the heck the yellow thing on the right of your photo was, as it didn't look familiar. I finally realized it's a light.
    • nhbouch
      • Aug 2016
      • 41
      • Bedford NH
      • 2007 SV211 Team
      Just replaced my port side negative battery cable this spring. Snapped a pic for you....hopefully this helps you find the stud. If you are looking down at the motor from the rear(removable) seat, it's below the FCC - just to the right, on the front face (towards the bow) of the motor.
      • Mahoo
        • Oct 2008
        • 27
        • Georgetown Texas
        • 2005 SV211 team
        Thanks for the reply nhbouch​. I found the connections in your picture and those connections are still in place on my boat. That ground wire goes to my battery. I dug around some more and found a 5/16 tapped hole in block up under the exhaust manifold so I just used that. Done.
        • Scooter G
          • Jan 2022
          • 1320
          • On a Lake in Idaho
          • 2022 G23 ZZ8
          You suppose the old bolt is floating somewhere in the mysterious black hole under the engine, where things go never to be seen again?
          I know for certain there is a boxed end wrench, socket, and engine drain plug in the depths of my gallows. No stiff wire, bright light, mirror, or magnet will return their presence from Planet Methuselah.
