Hello,
Need some ideas on what could be going wrong on our ski boat. We launched it 2 days ago and it’s been sitting in the lift since then. It started fine and made it across the lake with no issues, however when we went to start it today the only electrical component that works on it is the bilge pump. This boat has a keyless ignition - one where you put in a code to start it. We’ve had issues with this in the past so it could be the problem. There’s also a switch to turn all systems on/off and only the bilge on which may be another spot. We’ve checked the battery which has full charge.
