2013 G23 Keypad wiring/voltage/etc
  • shoeish
    • Jul 2023
    • 1
    • Colorado
    • 2013 G23
    They Keypad on my 2013 G23 is being weird. It only blinks for a certain number of button presses then stops. New batteries, good connections, etc. Pulled the plug and can't seem to find any voltage. Plugged back in, engine started, then keypad wouldn't respond to turn the engine off (had to pull fuel pump relay to get it to stop). Not its just acting the same; poorly.
    The LINC doesn't seem to want to work through all this.
    Where does the power come from for the keypad? I can't seem to trace the wire. Assuming directly from the breaker panel but can't be sure. "Jumped" the breaker to check and it didn't seem to help.
    Any ideas otherwise?
    Ordered a new keypad but want to ensure voltage is good before throwing a $600 part at the boat.
    Thanks all.
