Any tips on freeing a struck transom drain plug?
  • SilentSeven
    • Feb 2014
    • 1867
    • Bellevue WA
    • 2004 Nautique 206
    Need to remove my transom drain plug but it's not coming free. I don't want to overly reef on it as I'm nervous the hull side housing will tear out. Anyone have any tricks to free up a stuck plug?
    As long as I have owned this boat....I've never removed it - I always use the mid hull plug.
    Bellevue WA
  • Jonny Quest
    • Aug 2014
    • 384
    Soak it with acetone / ATF mixture. 50/50 mix. Give it several hours...or even over night. That should free things up. Then, install with a little marine grease on the threads.
    JQ
    • Scooter G
      • Jan 2022
      • 1320
      • On a Lake in Idaho
      • 2022 G23 ZZ8
      Be very selective with what that acetone touches, a few drops on threads will go a long ways...
      • SilentSeven
        • Feb 2014
        • 1867
        • Bellevue WA
        • 2004 Nautique 206
        Turns out PB Blaster penetrating oil works great. Sprayed it and let it soak a few minutes and it spun right out.
        Acetone and ATF sounds like a serious old school mechanics hack!
        Sent from my Pixel 7 using Tapatalk
        Bellevue WA
        • jmo
          • Mar 2006
          • 710
          • MA
          If it’s on the trailer, loosen the turn buckle and/or the winch strap, having them taught will affect how easily the drain plug comes out.
          2018 Ski Nautique 200 TE, H6
