Good afternoon, I've been lurking this forum for a while and now that I'm in possession of my new (new to me) 1999 ski nautique I'm working through all the elements of the TLC it so sorely missed and deserved.
One of them is the following 'issue' I'm having.
The boat starts up fine, but then proceeds to idle at around 860ish rpm. It also seems to have a bit of a rough idle, and feels like it misses every now and then, especially when first put into gear. It feels like the rpm is fluctuating a fair amount, but isn't directly reflected on the tach or my perfect pass display. It has yet to stall though. It smoothed out a bit after warming up, but was still rough and idling at 860 after a good 40 minutes of driving.
This is contrasted by the fact that the hole shot and cruising is unaffected. It's strong out of the hole and runs like a top at every speed over about 1000 rpm. Certainly a day of skiing on Saturday saw it run flawlessly for what we needed.
The boat itself sat for about a year before I bought it, and looks to have been out in the elements, judging by the surface corrosion found on some of the metal hardwear in the interior, and found in places on the engine itself.
The battery did die on me on Saturday when I was installing the upgraded perfect pass system, though I had chalked that up to having had the accessory mode, auto bilge etc running for large periods of time without the engine running, so I've taken that out and put it on a battery charger (it was sitting at about 75% charged following a 30-40 minute continuous drive).
I've through some of the other GT-40 idling threads but haven't found a situation that clearly mirrors my own, so I figured I'd ask the crowd.
Thanks in advance!
Thanks in advance!
