2000 SAN mystery gasket
  • msquito
    • Jun 2020
    • 82
    • WA
    • 2000 Super Air Nautique
    so, I'm reworking the ballast routing and pump installation in our 2000 SAN, and I pulled this out of the bilge Sunday night - about 4" x 42" x 1/4" thick IIRC - where did this come from (or more importantly, where should it be???)
    thx all
  • JayG80
    • Dec 2006
    • 206
    • Santa Fe, TX
    • 2007 Ski Nautique Sold 2002 Ski Nautique
    Maybe under the strap on fuel tank?
    • msquito
      • Jun 2020
      • 82
      • WA
      Seems reasonable, definitely strap-shaped...
      I've taken apart much of the boat (most of it put back together too), but haven't ever figured out how to get the rear floor panel up. Couldn't find any screws, and was reluctant to start prying...
      • JayG80
        • Dec 2006
        • 206
        • Santa Fe, TX
        I am not a SAN owner but it seems the screw heads can disappear in the carpeting. I'd carefully look near the corners and edges of the floor panel.
        • SilentSeven
          • Feb 2014
          • 1854
          • Bellevue WA
          • 2004 Nautique 206
          Looks like the rubber bushing that fits under a tank. Ballast or fuel.
          Sent from my Pixel 7 using Tapatalk
          Bellevue WA
          • msquito
            • Jun 2020
            • 82
            • WA
            okay, so if that''s an "under the fuel tank" type of thing (I have pulled out the factory ballast)... that seems like an involved replacement job (assuming I'm able to get past my personal problems with the rear floor panel)...
            • Rednucleus
              • Jul 2022
              • 177
              • WA
              • Club Boat 2014 Ski Nautique 200
              Maybe it was under the factory ballast you pulled out??
              • SilentSeven
                • Feb 2014
                • 1854
                • Bellevue WA
                • 2004 Nautique 206
                Yup......what Rednucleus said.
                Bellevue WA
                • msquito
                  • Jun 2020
                  • 82
                  • WA
                  Nah, those were hard tanks on either side of the engine (or did I miss some!?). This came from forward in the bilge. I've crammed myself back there enough times since pulling those tanks to be confident it didn't come from those. Good thinking though! Based on what I'm hearing, my gut suggests it's likely fuel tank related given where it came from...
                  • s_kelley2000
                    • 1575
                    • Fort Meadow Recevoir
                    • Mass
                    Assuming that 2000 is the same as 99, you need to remove the plastic pieces that form the rear seat base(and possible side seat bases). You at least have to unfasten the horizontal round screw pins that connect the separate plastic bases.. Some of those screws that hold the rear bases in place go right threw and hold the floor down. There also is likely a couple screws hidden in the carpet pile.
                    That piece you found looks like it it's part of the full tank hold down strap as others have said. I'd inspect once. you get the floor up but it wouldn't shock me if the worker dropped it in the bilge during initial install and just grabbed another one and it eventually worked it ways to the back of the bilge.
                    Shawn
                    2012 Blue Metal Flake SAN 230
