2006 210 TE - Ballasts not draining
  • Kenogamissi SANTE
    • Jun 2024
    • 13
    • Timmins Ontario
    • 2007 SANTE
    I apologize if this has already been covered, I had no luck finding the solution. Took my 2006 SANTE out of storage and my ballasts fill but don’t drain. The lights on the control panel flash as they should but the relays in the power box don’t fire. This is the case for all 3 ballasts. Has anybody here already dealt with this? Any ideas of what could be wrong between the switch and relays?
    I did play with the 3 adjustment screws under the dash but that didn’t seem to help anything. Ballast gauges all seem to be functioning.
    any help would be greatly appreciated.
    thanks!
  • biacs
    • Aug 2020
    • 252
    • IL
    • 2006 Nautique 220 Team Edition
    This may be longshot if all three I have an issues.
    Take the wiring harness of one tank and make a little jumper to connect the terminals, and see if the tank drains.
    If those float switches are DOA they won't tell the pump to drain.
    Again long shot all three are bad, but that's a symptom I had on my center center ballast.
    • Kenogamissi SANTE
      • Jun 2024
      • 13
      • Timmins Ontario
      • 2007 SANTE
      Hi biacs, I did end up finding this info in an older post. This did not work for me so now I’m moving on to building jumpers that will reverse the polarity at each pump for me. Kind of a PITA but at least I can empty the ballasts on the lake until I figure out the issue.
