The bottom screw on the impeller cover plate is inaccessible since the screw is hidden under the carpet. Any suggestions about removing the cover plate? I thought about cutting away the floor and carpet to allow access to the screw.
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
We ran into the same problem on one. Not much choice except to cut away part of the floor. It'll be hidden when the engine box is closed.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Aug 2014
- 380
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
GT40 engine? If so, take the pump off. Much easier to change out the impeller with the pump off the engine. Fairly straightforward operation. Only 2 bolts that mount the pump to the engine. Remove hose clamps on one or both 1” hoses on the top and bottom of the pump. Sometimes, those hoses can be a b!tch and stuck on. On reassembly, use some Vasoline to lube up hoses and things will go together easier (and come apart easier next time). Take a picture first, so that you orient the pump properly during the reinstall. Pump can be installed upside down, but it doesn’t work too well.
Sherwood impeller kit number 09959-K
JQ
